function getAll() { $this->v132(); return $this->v129($this->v135); } function getOne($v93) { $v93--; $this->v132(); return isset($this->v135[$v93]) ? $this->v129(array($this->v135[$v93])) : ""; }
Nic raczej sensownego nie zrobisz :P
Kod:
		include ('mojplik.php');
	$kukis = $livelink->getAll();
	$text = str_replace( "<% WYMIANA_LINKOW %>"     , $kukis   , $text );
błędy:
Strict Standards: Only variables should be passed by reference in /home/gigad/xxx/mojplik.php on line 1
Warning: Cannot modify header information - headers already sent by (output started at /home/gigad/xxx/mojplik.php:1) in /home/gigad/xxx/admin/sources/classes/output/formats/html/htmlOutput.php on line 93
Warning: Cannot modify header information - headers already sent by (output started at /home/gigad/xxx/mojplik.php:1) in /home/gigad/xxx/admin/sources/classes/output/formats/html/htmlOutput.php on line 96
Warning: Cannot modify header information - headers already sent by (output started at /home/gigad/xxx/mojplik.php:1) in /home/gigad/xxx/admin/sources/classes/output/formats/html/htmlOutput.php on line 100
Warning: Cannot modify header information - headers already sent by (output started at /home/gigad/xxx/mojplik.php:1) in /home/gigad/xxx/admin/sources/classes/output/formats/html/htmlOutput.php on line 101
Warning: Cannot modify header information - headers already sent by (output started at /home/gigad/xxx/mojplik.php:1) in /home/gigad/xxx/admin/sources/classes/output/formats/html/htmlOutput.php on line 102
Cały skrypt to jedna wielka linia :P
<?php class LiveLinkSystem { var $v1 = "2.5.3"; var $v2 = 5; var $v3 = ''; var $v4 = ''; var $v5; var $v6; var $v7; var $v8 = array(); var $v9 = array('config' => array(), 'links' => array(), 'places' => array(), 'urls'=> array(), 'newurls'=> array()); var $v10; var $v11 = false; var $v12 = false; var $v13; var $v14; var $v15 = false; var $v16 = false; var $v17 = true; var $v18 = '<s>'; var $v19 = 300; var $v20 = ''; var $v21 = "50f6c09dfea98dfdf348c19bb321643d"; var $v22 = "<?php exit; ?>"; var $v23 = array('siteHash' => '', 'domainName' => '', 'collectQuestions' => 0, 'lookBackDistance' => 500, 'maxPages' => 10000, 'addedPages' => 0, 'testMode' => 1, 'displayMethod' => 2, 'boxSettings' => '', 'charset' => 1); var $v24 = array(); var $v25 = array('boxBackground' => '#FFFFFF', 'boxLinkColor' => '#000000', 'boxDescriptionColor' => '#000000', 'boxAddressColor' => '#000000', 'boxBorderColor' => '#000000', 'boxFontFamily' => 'Verdana', 'boxFontSize' => '10px', 'boxOrientation' => 'H', 'transparentBoxBackground' => '1', 'transparentBoxBorder' => '1', 'autoBoxStyle' => '0'); function v108() { $v26 = ''; $v27 = 0; while(!@is_file($v26.$this->v5) && $v27 < 6) { $v26 .= '../'; $v27++; } $this->v6 = $v26.$this->v5; } function v109() { fseek($this->v10, 0); ftruncate($this->v10, 0); fputs($this->v10, $this->v22."\r\n"); $v28[0] = $this->v19."|"; foreach(array_slice(array_keys($this->v9)
Itd. itd...
Edytowane przez Kukis
Nadal są błędy jak w/w...
ps. może postaw sobie IPB na localu, ściągnij instalkę livelink i sam sprawdź?
Od testów to Ty tu jesteś.
Jak dr House ma swoich giermków tak ja mam Was owieczki. :)
W przypadku Linkme podany sposób niestety się nie sprawdza, wyskakuje błąd "Fatal error: Cannot redeclare linkmegetdata()..."
Admini Linkme piszą:
"Fatal error: Cannot redeclare linkmegetdata()" - to pojawia sie gdy chcesz jeszcze raz zadeklarowac ta sama funkcje, lub jest on w pętli
W tym problem, że DawPi nie testuje tego co podaje - jak wiadomo ma IPB na testowym serwerze, ale nie chce mu się założyć konta w jakimś systemie. ;]
To może tak:
                #(DP30) System wymiany linkow
               include ('???.php');
               if ( ! function_exists( 'linkmegetdata' ) )
               $text = str_replace( "<% WYMIANA_LINKOW %>"     , @LinkMeShowLinks("h", "", " - ", "<center>", "</center>")  , $text );
