[problem] hide links from guests - pogrubia tekst
Przejdź do rozwiązania Rozwiązane przez Gość naXe,
Wgrałem modyfikację (TH) Hide Links From Guests 1.0.0
Po wgraniu jak potrzeba od momentu wyświetlenia się komunikatu: "zaloguj się itd" wszystko pogrubia aż po stopkę.
<?xml version="1.0" encoding="utf-8"?>
<hookexport>
  <hookdata>
    <config>
      <hook_name>(TH) Hide Links From Guest</hook_name>
      <hook_desc>Hides Links from guests</hook_desc>
      <hook_author>TheHappenen</hook_author>
      <hook_email>[email protected]</hook_email>
      <hook_website>http://thehappenen.com</hook_website>
      <hook_update_check/>
      <hook_requirements><![CDATA[a:3:{s:21:"required_applications";a:0:{}s:20:"hook_php_version_min";s:5:"3.2.0";s:20:"hook_php_version_max";s:0:"";}]]></hook_requirements>
      <hook_version_human>1.0.0</hook_version_human>
      <hook_version_long>1000</hook_version_long>
      <hook_extra_data><![CDATA[a:3:{s:7:"display";a:1:{s:8:"settings";s:76:"Setting groups: Hide Links From Guests<br />Settings: Hide Links From Guests";}s:13:"settingGroups";a:1:{s:0:"";s:16:"dg_hideLinkGuest";}s:8:"settings";a:1:{s:0:"";s:22:"dg_hideLinkGuest_onoff";}}]]></hook_extra_data>
      <hook_key>dg_hideLinkGuest</hook_key>
      <hook_global_caches/>
    </config>
  </hookdata>
  <hookfiles>
    <file>
      <hook_file_real>dg_hideLinkGuest.php</hook_file_real>
      <hook_type>skinHooks</hook_type>
      <hook_classname>dg_hideLinkGuest</hook_classname>
      <hook_data><![CDATA[a:8:{s:12:"dataLocation";s:0:"";s:14:"libApplication";s:0:"";s:15:"classToOverload";s:10:"skin_topic";s:9:"skinGroup";N;s:12:"skinFunction";N;s:4:"type";N;s:2:"id";N;s:8:"position";N;}]]></hook_data>
      <hooks_source><![CDATA[class dg_hideLinkGuest extends skin_topic(~id~)
      function post($post, $displayData, $topic, $forum=array())
		if($this->settings['dg_hideLinkGuest_onoff'] == 1)
       		if (!$this->memberData['member_id'])
				$dg_acc_register = $this->registry->getClass('output')->formatUrl( $this->registry->getClass('output')->buildUrl( "app=core&module=global&section=register", "public",'' ), "", "" );
				$dg_acc_login = $this->registry->getClass('output')->formatUrl( $this->registry->getClass('output')->buildUrl( "app=core&module=global&section=login", "public",'' ), "", "" );
            		$post['post']['post'] = preg_replace('#<a(.*?)rel=\'nofollow external\'(.*?)<(.*?)a>#', ' <p class=\'message error\'><span style=\'font-size:10pt\'>Please Login <a href="'.$dg_acc_login.'" style=\'text-decoration:none;\'><b>HERE</b></a> or Register <a href="'.$dg_acc_register.'" style=\'text-decoration:none;\'><b>HERE<b></a> to see this link!</span></p> ', $post['post']['post']);
	      return parent::post($post, $displayData, $topic, $forum=array());
}]]></hooks_source>
    </file>
  </hookfiles>
  <hookextras_settings>
    <setting>
      <conf_is_title>1</conf_is_title>
      <conf_title_title>Hide Links From Guests</conf_title_title>
      <conf_title_desc>Allows you to hide links from Guests</conf_title_desc>
      <conf_title_noshow>0</conf_title_noshow>
      <conf_title_keyword>dg_hideLinkGuest</conf_title_keyword>
      <conf_title_app>core</conf_title_app>
      <conf_title_tab>Hooks</conf_title_tab>
    </setting>
    <setting>
      <conf_id>611</conf_id>
      <conf_title>Hide Links From Guests</conf_title>
      <conf_description/>
      <conf_group>60</conf_group>
      <conf_type>yes_no</conf_type>
      <conf_key>dg_hideLinkGuest_onoff</conf_key>
      <conf_value/>
      <conf_default>0</conf_default>
      <conf_extra/>
      <conf_evalphp/>
      <conf_protected>0</conf_protected>
      <conf_position>1</conf_position>
      <conf_start_group/>
      <conf_add_cache>1</conf_add_cache>
      <conf_keywords/>
      <conf_is_title>0</conf_is_title>
    </setting>
  </hookextras_settings>
  <hookextras_language/>
  <hookextras_modules/>
  <hookextras_help/>
  <hookextras_templates/>
  <hookextras_css/>
  <hookextras_tasks/>
  <hookextras_database_create/>
  <hookextras_database_alter/>
  <hookextras_database_update/>
  <hookextras_database_insert/>
</hookexport>
Nie jestem programistą, co mam zrobić? :)
Zamień:
<b>HERE<b>
na:
<b>HERE</b>
  • Lubię to 2
