Problem tabelka webkolo - Warning: require() [function.require]: open_basedir restriction in effect.
Warning: require() [function.require]: open_basedir restriction in effect. File(/usr/lib/php/lgsl_class.php) is not within the allowed path(s): (/home/:/tmp) in /home/unixgame/public_html/serverviewer/admin/lgsl_list.php on line 13
Warning: require() [function.require]: open_basedir restriction in effect. File(/usr/local/lib/php/lgsl_class.php) is not within the allowed path(s): (/home/:/tmp) in /home/unixgame/public_html/serverviewer/admin/lgsl_list.php on line 13
Warning: require() [function.require]: open_basedir restriction in effect. File(/usr/lib/php/geoip.inc.php) is not within the allowed path(s): (/home/:/tmp) in /home/unixgame/public_html/serverviewer/admin/lgsl_class.php on line 15
Warning: require() [function.require]: open_basedir restriction in effect. File(/usr/local/lib/php/geoip.inc.php) is not within the allowed path(s): (/home/:/tmp) in /home/unixgame/public_html/serverviewer/admin/lgsl_class.php on line 15
Table 'unixgame_przemo.wk_lgsl' doesn't exist
mam o to taki błąd
niz z tego nie rozumiem :D moglbys mi wytlumaczyc co i jak?
