(DP34) Referrals System
Zobacz plik
With this app you can allow your members invite other members.
Features:
  • enable/disable system,
  • select allowed groups to use this mod,
  • three invite types: free -> user may or may not enter inviter name; force -> user must enter inviter name; invite only: user must be referred by invite form (with hashed keycode),
  • list of all invited users,
  • list of all invited users in ACP with filter option for search invited members for specific user,
  • invites by referral link,
  • points system integration ( any system! ),
  • promotion to the new group after reaching specific amount of referred users,
  • ability to enable/disable member powers to raising people via ACP,
  • ability to check all referred users via ACP ( member manage ),
  • three notification methods: PM, E-mail or Inline,
  • info in member profiles about referrer,
  • top X referrers in sidebar,
  • ability to disable the 'Referral Link' in sidebar,
  • ability to add/edit/remove referred transactions,
  • ability to turn off the "Referrer Information" block in profiles,
  • ACP permissions (manage: add, remove, edit),
  • ability to award referrer if his referrred member made topic/post,
  • ranking with filters in the ACP view,
  • enhaced filters for referral transactions,
  • invite form,
  • option to enable/disable custom invite message,
  • option to disable invites from the same IP,
  • resend option to resend sent invites,
  • option to approve transaction only if referrer add more than X defined posts.
  • and more!
