RESOLVED: Help with code(Again^^,)
Hey, i wanna say think you for the help before, but, my members wanna see "commets" above the Stars..
ex1: Comments: 0
ex2: Comments: 7
Here are the code:
<table class='ipb_table' cellspacing="100">
   <tbody>
       <tr>
           <td class='row1'>
       /* Init */
       $return  = "";
       $to_show = 36;
       $per_row = 6;
       $count   = 0;
       /* Query */
       $this->DB->build( array( 'select'   => 'i.id AS picid, i.masked_file_name, i.directory, i.caption, i.member_id, i.ratings_count, i.ratings_total ',
                                                        'from'     => array( 'gallery_images' => 'i' ),
                                                        'add_join' => array( 0 => array( 'select' => 'g.rate AS number',
        'from'   => array( 'gallery_ratings' => 'g' ),
        'where'  => 'i.id=g.img_id',
        'type'   => 'left' ) ),
                                                        'add_join' => array( 1 => array( 'select' => 'm.name as uname',
        'from'   => array( 'members' => 'm' ),
        'where'  => 'i.member_id=m.member_id',
                                                        'order'    => 'i.id DESC',
                                                        'limit'    => array( 0, $to_show ),
       $this->DB->execute();
       /* Got some rows */
       if ( $this->DB->getTotalRows() )
               $return .= "<div><table>";
               while ( $row = $this->DB->fetch() )
                       $count++;
                       $row['rate']['id'] = intval( $row['picid'] );
                       $row['rate']['number'] = intval( $row['number'] );
                       $row['rate']['canrate']         = 1;
                       $row['rate']['_rate_int'] = $row['ratings_count'] ? round( $row['ratings_total'] / $row['ratings_count'], 0 ) : 0;
                       $row['number'] = $this->registry->output->getTemplate( 'gallery_imagelisting' )->rate_form( $row['rate'] );
                       $return .= <<<EOF
       <td class='short'>
               <a href="index.php?app=gallery&module=images&section=viewimage&img={$row['picid']}">
                       <img src="uploads/{$row['directory']}/tn_{$row['masked_file_name']}" alt="{$row['caption']}" />
               </a><br />
               <i>Uploaded By:</i><br>
               <a href='index.php?app=gallery&module=user&user={$row['member_id']}'><b>{$row['uname']}</b></a></strong><br />{$row['number']}
      </td>
EOF;
                       /* New row */
                       if ( $count && $count % $per_row == 0 )
                               $return .= "</tr><tr>";
               $return .= "</tr></table></div>";
       /* Return */
       print $return;
Hi,
try this:
   <tbody>
       <tr>
           <td class='row1'>
       /* Init */
       $return  = "";
       $to_show = 36;
       $per_row = 6;
       $count   = 0;
       /* Query */
       $this->DB->build( array( 'select'   => 'i.id AS picid, i.masked_file_name, i.directory, i.caption, i.member_id, i.ratings_count, i.ratings_total, i.comments ',
       /* Got some rows */
                       $count++;
                       $return .= <<<EOF
       <td class='short'>
               </a><br />
               <br />
               Comments: {$row['comments']}
      </td>
EOF;
                       /* New row */
       /* Return */
       print $return;
thanks! but one thing, sorry for the questions but you are only one who helped me with this :) and, im Thankful!
Is it possible to make Comments, a link to the comments.?
like:
i uploaded a image, and a guy has made a comment, and i can just click on the "Comments", and i get to the comment that has been made @ my uploaded image :%-):!
Easy way:
Comments(will be a link) -> redirect to the image comments :)
Try this:
   <tbody>
       <tr>
           <td class='row1'>
       /* Init */
       $return  = "";
       $to_show = 36;
       $per_row = 6;
       $count   = 0;
       /* Query */
       /* Got some rows */
                       $count++;
                       $return .= <<<EOF
       <td class='short'>
               </a><br />
               <br />
               Comments: <a href="index.php?app=gallery&module=post&section=comment&do=postcomment&img={$row['picid']}">{$row['comments']}</a>
      </td>
EOF;
                       /* New row */
       /* Return */
       print $return;
thank you so much!!!! :P
and, one more tiny thing^^,)
is it a possibility to do the same(Comments & Stars) on Last Skin & Themes code i have:
<div class='moderation_bar rounded  clear'>
<center>
<i><b><h3>Skins & Themes</h3></font></i>
</center>
       /* Init */
       $return  = "";
       $to_show = 24;
       $per_row = 6;
       $count   = 0;
       /* Query */
       $this->DB->build( array( 'select'   => 'f.file_id, f.file_name, f.file_ssname',
                                                        'from'     => array( 'downloads_files' => 'f' ),
                                                        'add_join' => array( 0 => array( 'select' => 'm.name as uname',
        'where'  => 'f.file_submitter=m.member_id',
                                                        'order'    => 'f.file_id DESC',
       /* Got some rows */
               $return .= "<div><table><tr>";
                       $count++;
                       $return .= <<<EOF
<td class='short'>
       <a href="index.php?app=downloads&showfile={$row['file_id']}">
EOF;
                       if ( $row['file_ssname'] )
                               $return .= <<<EOF
               <img src="index.php?app=downloads&module=display&section=screenshot&id={$row['file_id']}" width='128' height='100'  alt="{$row['file_name']}" />
EOF;
                       else
                               $return .= <<<EOF
               <em>No Screenshot Available</em>
EOF;
                       $return .= <<<EOF
       </a><br />
       <i>By:</i> <strong>{$row['uname']}</strong><br> In <a href="http://wallbase.org/index.php?app=downloads"> Skins & Themes</a>
</td>
EOF;
                       /* New row */
       /* Return */
       print $return;
Edytowane przez Tricky
  • 1 miesiąc temu...
