nie chce męczyć angielskiego, i wole Ciebie :) chce porównać taki bit szablonu gdzie jest ten przycisk z moim bitem gdzie go nie ma, bo tak jak stronę wcześniej zasugerowałeś dodać kawałek kodu i się w widoku blogu włączył przycisk, tylko na stronie głównej mi go brak :<
Oryginalny:
[long]
{parse js_module="blog"}
<!--[if lt IE 8]>
<style type='text/css'>
/* IE HACK */
html #cblock_left {
left: 275px; /* Right width */
html #main_blog_wrapper #cblock_left.cblock.temp {
left: 275px !important;
</style>
<![endif]-->
ipb.vars['blog_id'] = parseInt( {$blog['blog_id']} );
ipb.vars['blog_url'] = "{$blog['blog_url']}";
ipb.blog.goComments = {parse expression="intval($this->request['_gocomments'] )"}
ipb.lang['confirm_delete'] = "{$this->lang->words['blog_sure_delcblock']}";
ipb.lang['confirm_reset'] = "{$this->lang->words['blog_theme_reset']}";
ipb.lang['blog_sure_delcblock'] = "{$this->lang->words['blog_sure_delcblock']}";
ipb.lang['copy_entry_link'] = "{$this->lang->words['permalink_prompt']}";
</script>
<if test="showDisabledBox:|:$blog['blog_disabled'] AND $this->memberData['g_is_supmod']">
<div class='message error'>
<h4>{$this->lang->words['blog_global_disabled_title']}</h4>
{parse expression="sprintf( $this->lang->words['blog_global_disabled_desc'], $this->settings['base_url'] . 'app=blog&module=post&section=mod&do=toggledisable&disable=0&blog_id=' . $blog['blog_id'] . '&auth_key='.$this->member->form_hash )"}
<br />
<if test="includeCustomThemes:|:$this->settings['blog_themes_custom']">
var clientImagePath = "{$this->settings['_original_base_url']}/blog/colorpicker/images/";
</script>
<script type="text/javascript" src="{$this->settings['_original_base_url']}/blog/colorpicker/colormethods.js" ></script>
<script type="text/javascript" src="{$this->settings['_original_base_url']}/blog/colorpicker/colorvaluepicker.js" ></script>
<script type="text/javascript" src="{$this->settings['_original_base_url']}/blog/colorpicker/slider.js" ></script>
<script type="text/javascript" src="{$this->settings['_original_base_url']}/blog/colorpicker/colorpicker.js" ></script>
.colorpicker {
display: block;
.margin{
margin-top: 1px;
margin-left: 3px;
</style>
<if test="$this->request['module'] != 'post'">
<div class='blog_tab_wrap <if test="!$this->memberData['member_id']">guest</if>'>
<if test="wotwelookingat:|:$this->request['module'] == 'display'">
<div class='blog_top_tab alt left'>
<div id='blogsubs'>
{parse expression="sprintf( $this->lang->words['bglobal_sub_to'], $blog['blog_name'] )"}
<if test="trackblog:|:$this->memberData['member_id'] && $blog['tracker_id'] == ''">
<a href='{parse url="app=core&module=usercp&tab=blog&area=tracker&do=trackblog&blogid={$blog['blog_id']}" base="public"}' title='{$this->lang->words['track_this_blog']}'>{parse replacement="watch_topic_on"}</a>
<if test="endtrackblog:|:$this->memberData['member_id'] && $blog['tracker_id'] != ''">
<a href='{parse url="app=core&module=usercp&tab=blog&area=tracker&do=endtrackblog&blogid={$blog['blog_id']}" base="public"}' title='{$this->lang->words['end_track_blog']}'>{parse replacement="blog_watch_off"}</a>
<if test="blogrss:|:$blog['blog_id'] AND $blog['blog_settings']['allowrss']">
<if test="feedburnerlink:|:$blog['blog_settings']['rssfeedburner']">
<a href="http://feeds.feedburner.com/{$blog['blog_settings']['rssfeedburner']}" title='{$this->lang->words['blog_syndicate']}'><img src='{$this->settings['img_url']}/feed.png' alt='{$this->lang->words['rss_feed']}'/></a>
<else />
<a href="{parse url="app=core&module=global&section=rss&type=blog&blogid={$blog['blog_id']}" template="blogrss" seotitle="{$blog['blog_seo_name']}" base="public"}" title='{$this->lang->words['blog_syndicate']}'><img src='{$this->settings['img_url']}/feed.png' alt='{$this->lang->words['rss_feed']}'/></a><br />
<if test="viewerismember:|:$this->memberData['member_id'] ">
<div class='topic_controls'>
<ul class='topic_buttons'>
<if test="gobuttonbutton:|:is_array($this->memberData['has_blog']) AND count($this->memberData['has_blog'])">
<li><a id='bloggobutton' class='ipbmenu' href='{parse url="app=core&module=usercp&tab=blog" base="public"}'>{parse replacement="blog_go"} {$this->lang->words['blog_button_go']}<img src='{$this->settings['img_url']}/opts_arrow.png' alt='>' class='arrow' /></a></li>
<else />
<if test="canstartblog:|:$this->memberData['member_id'] AND ( $this->memberData['g_blog_allowcreate'] OR $this->memberData['g_blog_allowlocal'])">
<li><a href='{parse url="app=core&module=usercp&tab=blog" base="public"}'>{parse replacement="approve"} {$this->lang->words['blog_button_start']}</a></li>
<if test="allowentry:|:$this->memberData['has_blog']">
<if test="howmanyblogs:|:! is_array($this->memberData['has_blog']) OR count($this->memberData['has_blog']) < 2">
<li><a href='{parse url="app=blog&module=post&section=post&do=showform&blogid={$blog['blog_id']}" base="public"}'>{parse replacement="blog_add_entry"} {$this->lang->words['add_entry']}</a></li>
<else />
<li><a id='addentrylink' class='ipbmenu' href='{parse url="app=blog&module=post&section=post&do=showform&blogid={$blog['blog_id']}" base="public"}'>{parse replacement="blog_add_entry"} {$this->lang->words['add_entry']} <img src='{$this->settings['img_url']}/opts_arrow.png' alt='' class='arrow' /></a></li>
<if test="cblockjs:|:$this->registry->getClass('blogFunctions')->ownsBlog( $blog, $this->memberData ) AND ipsRegistry::$current_module != 'post'">
<li><a href='#blocks' id='content_blocks' class='ipbmenu'>{parse replacement="blog_blocks"} {$this->lang->words['add_cblocks']}<img src='{$this->settings['img_url']}/opts_arrow.png' alt='>' class='arrow' /></a></li>
<if test="themejs:|:)$this->settings['blog_themes'] AND $theme_js) && $this->registry->getClass('blogFunctions')->ownsBlog( $blog, $this->memberData ) AND ipsRegistry::$current_module != 'post'">
<li><a href='#themes' id='themes_menu' class='ipbmenu'>{parse replacement="blog_theme"} {$this->lang->words['themes_menu']}<img src='{$this->settings['img_url']}/opts_arrow.png' alt='>' class='arrow' /></a></li>
<if test="headerjs:|:/$this->settings['blog_headers'] AND $header_js) && $this->registry->getClass('blogFunctions')->ownsBlog( $blog, $this->memberData ) AND ipsRegistry::$current_module != 'post'">
<li><a href='#header' id='change_header'>{parse replacement="blog_header"} {$this->lang->words['headers_menu']}</a></li>
</ul>
{$cblock_control}
{$header_js}
{$theme_js}
{parse template="headerMenus" group="blog_global" params="$blog"}
[/long]
  • 8 miesięcy temu...
Odświeżam temat... :(
Po instalce IPBlog 2.3.2 mam też problem z tymi nieszczęsnymi przyciskami - po prostu ich nie ma.
Efekt jest taki że można założyć blog ale nic w nim napisać się nie da.
Jak z tego wybrnąć?
;) Ładnie tak się podśmiewać z kogoś? :) Błędów nie popełnia podobno tylko ten kto nic nie robi....
Ale na poważnie - chyba już łapię gdzie został popełniony błąd i widzę że nie tylko u mnie. Prawdopodobnie pliki z paczki zostały wrzucone nie tam gdzie powinny się znaleźć.
DawPi - mam prośbę. Mógłbyś zrobić taką rozpiskę gdzie co się wrzuca podczas instalacji IPBlog z paczki pobranej z IPS ? Łącznie ze spolszczeniami.
Edytowane przez jozefg
  • 2 miesiące temu...
Odkopuje, ale ten sam problem w 3.2.1 i najnowszym blogu. Nie mam guziczka. W bazie zamieniam has_blog na 1, wchodze na blog - dalej nic. Wracam do bazy a tam już 0 :(
Przeoczyłem jakiś opis? Przecież nie ustawie domyślnie 1 dla każdego.
Wychodzi na to, że coś usilnie zmienia tę wartość na 0. Wyłącz rozszerzenia blogowe i wtedy sprawdź. Jak nie pomoże to rzucę okiem w kod.
Masz domyślne bity skina czy edytowane i podczas aktualizacji się nie zaktualizowały? Czerwone kropy obok nazw?
Są aktualizacje, ale sam je wprowadzałem tylko dodając własne klasy oraz identyfikatory ew. !important :) bo tło bloga (dynamiczny) jest bez sensu zrobiony.
Tak, robił to hook ostatnie wpisy na blogu. Ale mając już 1 dalej nie mam guzika. Napisze ticketa, chyba, że coś wymyśle zaraz.
Dodatkowo używając guzika "dodaj na blog" w topiku widzę :
[#106330,2] Nie posiadasz obecnie żadnych blogów. Utwórz jeden i spróbuj ponownie
A blog to ja mam :)
