(DP31) Topic Starter Info
Kodzik
[long]<ul class='user_details'>
<if test="avatar:|:$author['member_id'] AND $author['avatar']">
<li class='avatar'><a href="{parse url="showuser={$author['member_id']}" template="showuser" seotitle="{$author['members_seo_name']}" base="public"}" title="{$this->lang->words['view_profile']}">{$author['avatar']}</a></li>
<else />
<li class='avatar'>{$author['avatar']}</li>
<if test="membertitle:|:$author['title']">
<li class='title'>{$author['title']}</li>
<if test="rankimage:|:$author['member_rank_img']">
<li class='group_icon'>
<if test="rankimageimage:|:$author['member_rank_img_i'] == 'img'">
<img src='{$author['member_rank_img']}' alt='' />
<else />
</li>
</ul>
<div style='margin: 0 auto;'>
<if test="xhtmlftw:|:$this->memberData['member_id'] != $author['member_id'] OR ($author['has_blog'] AND IPSLib::appIsInstalled( 'blog' )) OR ($author['has_gallery'] AND IPSLib::appIsInstalled( 'gallery' ))">
<ul class='user_controls clear'>
<if test="friendop:|:$this->memberData['member_id'] AND $this->memberData['member_id'] != $author['member_id'] && $this->settings['friends_enabled'] AND $this->memberData['g_can_add_friends'] && $author['member_id']">
<if test="isfriend:|:IPSMember::checkFriendStatus( $author['member_id'] )">
<li class='mini_friend_toggle is_friend' id='friend_{$contentid}_{$author['member_id']}'><a href='{parse url="app=members&module=profile&section=friends&do=remove&member_id={$author['member_id']}&secure_key={$this->member->form_hash}" base="public"}' title='{$this->lang->words['remove_friend']}'>{parse replacement="remove_friend"}</a></li>
<else />
<li class='mini_friend_toggle is_not_friend' id='friend_{$contentid}_{$author['member_id']}'><a href='{parse url="app=members&module=profile&section=friends&do=add&member_id={$author['member_id']}&secure_key={$this->member->form_hash}" base="public"}' title='{$this->lang->words['add_friend']}'>{parse replacement="add_friend"}</a></li>
<if test="sendpm:|:$this->memberData['g_use_pm'] AND $this->memberData['member_id'] != $author['member_id'] AND $this->memberData['members_disable_pm'] == 0 AND IPSLib::moduleIsEnabled( 'messaging', 'members' ) && $author['member_id']">
<li class='pm_button' id='pm_{$contentid}_{$author['member_id']}'><a href='{parse url="app=members&module=messaging&section=send&do=form&fromMemberID={$author['member_id']}" base="public"}' title='{$this->lang->words['pm_member']}'>{parse replacement="send_msg"}</a></li>
<if test="hasblog:|:$author['has_blog'] AND IPSLib::appIsInstalled( 'blog' ) AND $author['has_blog'] != 'recache'">
<li><a href='{parse url="app=blog&show_members_blogs={$author['member_id']}" base="public"}' title='{$this->lang->words['view_blog']}'>{parse replacement="blog_link"}</a></li>
<if test="hasgallery:|:$author['has_gallery'] AND IPSLib::appIsInstalled( 'gallery' )">
<li><a href='{parse url="app=gallery&module=user&section=user&user={$author['member_id']}" base="public"}' title='{$this->lang->words['view_gallery']}'>{parse replacement="gallery_link"}</a></li>
</ul>
<ul class='user_fields'>
<li>
<span class='ft'>{$this->lang->words['m_group']}</span>
<span class='fc'>{$author['_group_formatted']}</span>
</li>
<if test="ismember:|:$author['member_id']">
<li>
<span class='ft'>{$this->lang->words['m_posts']}</span>
<span class='fc'>{parse expression="$this->registry->getClass('class_localization')->formatNumber( intval( $author['posts'] ) )"}</span>
<if test="$this->memberData['g_access_points']">
<dt>iPoints:</dt>
<dd>
<if test="!$author['p_locked']">
{parse expression="$this->registry->getClass('class_localization')->formatNumber( intval( $author['points'] ) )"}
<if test="$author['member_id'] != $this->memberData['member_id'] AND $this->memberData['g_donate_points']">
(<a href='{parse url="app=points&cmd=donate&id={$author['member_id']}" base="public"}' style='text-decoration:none;'>Donate</a>)
<else />
Locked
</dd>
</li>
<li>
<span class='ft'>{$this->lang->words['m_joined']}</span>
<span class='fc'>{parse date="$author['joined']" format="joined"}</span>
</li>
<if test="authorcfields:|:$author['custom_fields'] != """>
<foreach loop="customFieldsOuter:$author['custom_fields'] as $group => $data">
<foreach loop="customFields:$author['custom_fields'][ $group ] as $field">
<if test="$field != ''">
<li>
{$field}
</li>
</foreach>
</foreach>
</ul>
<if test="authorwarn:|:$author['warn_percent'] !== NULL">
<br class='clear' />
<div class='warn_panel clear rounded'>
<if test="$this->settings['warn_show_rating']">
<strong><a href='{parse url="app=members&module=warn&section=warn&do=view&mid={$author['member_id']}" base="public"}' id='warn_link_{$contentid}_{$author['member_id']}' title='{$this->lang->words['warn_view_history']}' class='warn_link'>{$this->lang->words['warn_status']}</a></strong>
<p class='rating_mode user_warn' title='{$this->lang->words['warn_level']} {$author['warn_percent']}%'>
<if test="changewarn:|:$author['can_edit_warn']">
<a href='{parse url="app=members&module=warn&section=warn&type=minus&mid={$author['member_id']}&t=0&st=0" base="public"}' title='{$this->lang->words['warn_decrease']}'><img src='{$this->settings['img_url']}/warn_minus.gif' alt='{$this->lang->words['minus']}' class='warn_edit down' /></a>
< {$this->settings['warn_min']} ( {$author['warn_level']} ) {$this->settings['warn_max']} >
<a href='{parse url="app=members&module=warn&section=warn&type=add&mid={$author['member_id']}&t={$this->request['t']}&st={$this->request['st']}" base="public"}' title='{$this->lang->words['warn_increase']}'><img src='{$this->settings['img_url']}/warn_add.gif' alt='{$this->lang->words['add']}' class='warn_edit up' /></a>
</p>
<else />
<a href='{parse url="app=members&module=warn&section=warn&type=add&mid={$author['member_id']}&t={$this->request['t']}&st={$this->request['st']}" base="public"}' title='{$this->lang->words['warn_increase']}'><img src='{$this->settings['img_url']}/warn_add.gif' alt='{$this->lang->words['add']}' class='warn_edit up' /></a><a href='{parse url="app=members&module=warn&section=warn&type=minus&mid={$author['member_id']}&t=0&st=0" base="public"}' title='{$this->lang->words['warn_decrease']}'><img src='{$this->settings['img_url']}/warn_minus.gif' alt='{$this->lang->words['minus']}' class='warn_edit down' /></a>
<if test="highwarn:|:$author['warn_percent'] >= 80">
<p class='progress_bar user_warn limit' title='{$this->lang->words['warn_level']} {$author['warn_percent']}%'>
<else />
<p class='progress_bar user_warn' title='{$this->lang->words['warn_level']} {$author['warn_percent']}%'>
<span style='width: {$author['warn_percent']}%'><span>{$this->lang->words['warn_level']} {$author['warn_percent']}%</span></span>
</p>
</if>[/long]
Już
[long]<?php
// (DP31) Topic Starter Info
// Template Hook
// Author: DawPi
// Site: http://www.ipslink.pl
// Written on: 22 / 09 / 2010
// Copyright © 2010 DawPi
// All Rights Reserved
class dp3tsiSkinHook
* CONSTRUCTOR
function __construct()
/* Make registry objects */
$this->registry = ipsRegistry::instance();
$this->DB = $this->registry->DB();
$this->lang = $this->registry->getClass('class_localization');
public function getOutput()
# O.o
public function replaceOutput( $output, $key )
$postData = $this->registry->output->getTemplate('topic')->functionData['topicViewTemplate'][0]['post_data'];
$starterId = $this->registry->output->getTemplate('topic')->functionData['topicViewTemplate'][0]['topic']['starter_id'];
if( is_array( $postData ) AND count( $postData ) )
$tag = '<!--hook.' . $key . '-->';
$last = 0;
foreach( $postData as $pid => $post )
$pos = strpos( $output, $tag, $last );
if( $pos )
$string = ( ( $post['author']['member_id'] == $starterId ) && ! $post['post']['new_topic'] ) ? $this->lang->words['dp3_tsi_txt'] : '';
$output = substr_replace( $output, $string . $tag, $pos, strlen( $tag ) );
$last = $pos + strlen( $tag . $string );
$string = "";
return $output;
} // End of class[/long]
Wersja 3.1.4. Skin dobry, plik dobry.. Brak pomysłów. Trudno coś takiego zweryfikować na odległość. A może jednak inny skin mi wkleiłeś? Dziwne.
  • 7 miesięcy temu...
na 3.2.x również działa, więc możecie to też umieścić w IP.Downloads w sekcji modyfikacji do 3.2 ;]
  • 1 miesiąc temu...
Gość hiroshima
jakbyś mógł to zaktualizować to byłoby fajnie, bo trochę to dziwne, że grupa gość, moderator i wyżej widzi to dobrze a user ma niekiedy kilku autorów w tym samym temacie.
Na razie to taki szybki test.. Nie sprawdzałem, bo nie mam jak, ale Ty przetestuj (nieoficjalnie): xxx
Edytowane przez DawPi
Niedługo będzie w plikowni. ;)
Ja przetestowałem u siebie i zdaje się że działa (testowałem wyświetlanie przez różne grupy jak i przez autora tematu). Podmieniłem tylko span <span class="ipsBadge" style="background:green;"> ;) DawPi, może rozważył byś dodanie ustawień do tego hook'a? System on/off i formatowanie wyświetlanego napisu? Ale to tylko moja skromna propozycja.
