Problem z nowymi zakladkami na forum
adey
Przejdź do rozwiązania Rozwiązane przez Gama,
Kod jaki dodaje:
<li id='nav_home'><a href=https://www.facebook.com/ApoMuOnline title='Idź do FanPage' rel="home">FanPage</a></li>
Próbowałem wklejać w każdym miejscu globaltemplate pod: "<!-- ::: APPLICATION TABS ::: -->"
 Niżej kod
            <div id='primary_nav' class='clearfix'>
                <div class='main_width'>
                    <ul class='ipsList_inline' id='community_app_menu'>
                        <if test="showQuickNav:|:! ( ! $this->memberData['member_id'] && $this->settings['force_login'] ) && !($this->settings['board_offline'] && !$this->memberData['g_access_offline']) && $this->memberData['g_view_board']">
                            <li class='right'>
                                <a href="{parse url="app=core&module=global&section=navigation&inapp={parse expression="IPS_APP_COMPONENT"}" base="public"}" rel="quickNavigation" accesskey='9' id='quickNavLaunch' title='{$this->lang->words['launch_quicknav']}'><span> </span></a>
                            </li>
                        <li id='nav_explore' class='right'>
                            <a href='{parse url="app=core&module=search&do=viewNewContent&search_app=<if test="viewnewcontentapp:|:$this->registry->getCurrentApplication() != 'core' AND IPSLib::appIsSearchable( $this->registry->getCurrentApplication() )">{$this->registry->getCurrentApplication()}<else />forums</if>" base="public"}' accesskey='2'>{$this->lang->words['view_new_posts']}</a>
                        </li>
                        <if test="showhomeurl:|:$this->settings['home_url'] AND $this->settings['home_name']">
                            <li id='nav_home' class='left'><a href='{$this->settings['home_url']}' title='{$this->lang->words['homepage_title']}' rel="home">{$this->settings['home_name']}</a></li>
                        <if test="hasCustomPrimaryNavigation:|:!empty($header_items['primary_navigation_menu'])">
                            {$header_items['primary_navigation_menu']}
                        <else />
                            <if test="applicationsloop:|:is_array($header_items['applications']) AND count($header_items['applications'])">
                                <foreach loop="applications:$header_items['applications'] as $data">
                                    <if test="showingapp:|:$data['app_show']">
                                        {parse variable="appActive" default="" oncondition="$data['app_active']" value="active"}
                                        <li id='nav_app_{$data['app_dir']}' class="left {parse variable="appActive"}"><a href='{parse url="{$data['app_link']}" seotitle="{$data['app_seotitle']}" template="{$data['app_template']}" base="{$data['app_base']}"}' title='{parse expression="sprintf( $this->lang->words['go_to_prefix'], IPSLib::getAppTitle($data['app_dir']) )"}'>{IPSLib::getAppTitle($data['app_dir'])}</a></li>
                                </foreach>
                        <li id='nav_other_apps' style='display: none'>
                            <a href='#' class='ipbmenu' id='more_apps'>{$this->lang->words['more_apps']} <img src='{$this->settings['img_url']}/useropts_arrow.png' /></a>
                        </li>
                    </ul>
A moze cos z wielkością ikonek zakłądek sie pobawic ?
Edytowane przez adey
To
Zamień na to i zobacz czy działa
<li id='nav_home' class='left'><a href=https://www.facebook.com/ApoMuOnline title='Idź do FanPage' rel="home">FanPage</a></li>
