Jump to content
Recommended Posts
Posted
(DP45) Referrals System
Zobacz plik
With this app you can allow your members invite other members.
Features:
  • enable/disable system,
  • select allowed groups to use this mod,
  • three invite types: free -> user may or may not enter inviter name; force -> user must enter inviter name; invite only: user must be referred by invite form (with hashed keycode),
  • list of all invited users,
  • list of all invited users in ACP with filter options,
  • invites by referral link,
  • points system integration (any system!),
  • promotion to the new group after reaching specific amount of referred users,
  • ability to enable/disable member powers to raising people via ACP,
  • info in member profiles about referrer,
  • ability to add/edit/remove referred transactions,
  • ability to turn off the "Referrer Information" block in profiles,
  • ability to award referrer if his referrred member made topic/post,
  • invite form,
  • option to enable/disable custom invite message,
  • option to disable invites from the same IP and much more,
  • resend option to resend sent invites,
  • option to approve transaction only if referrer add more than X defined posts.
Note:
  • it's a first release of this app for a 4.x series.
  • it's a lifetime purchase! Once time buy = lifetime updates (for a 4.x serie).
  • 1 month later...
Posted (edited)
Hello,
I have purchased the Referrals application and I wanted to discuss an issue I'm facing, but first of all, thank you for your work and your service.
I'm on a local test installation of IPS 4.7.3. and my problem is that I have configured the application to promote members to a group when they refer more than two guests. However, I have been conducting invitation and registration tests, and the application doesn't move the referring member, even though they have more than three referrals in their account. Do I need to configure something else for the system to work?
And another question: Does the application in any way interfere with the original IPS referrals application, or is it independent?
Looking forward to your response. Thank you very much.
Edited by McPearse
Posted
No problem, I'm here to help you guys! :)
Invited two guests doesn't mean that they registered from his referral url and activated their accounts. Did they?
Independent just like the United States every year on July 4th! ;)
Posted (edited)
"Thank you for your reply, DawPi.
In the app description, you state: "promotion to the new group after reaching specific amount of referred users."
In my case, guests will sign up via invitations. I want to use the app to encourage registration and the original IPS system for referrals and members commissions. For my community's dynamics, it's crucial that invitations and registrations are made by invitation only, and that a user can be moved to a different group after they've invited more than 'x' number of people who ultimately register in the community."
Edited by McPearse
Posted
And this is how it exactly work. Doesn't work for you? I can make some internal tests later today and show you that it work as designed.
Posted
The tests I have conducted on my installation are as follows:
'Member2' sends invitations to 'member3', 'member4', and 'member5'. These invitees register, following the link from the invitation, which I have set up as a custom URL in the AdminCP.
http://postimg.cc/4KNgYRvv
I have also set up the application so that when a member registers two invitees, they move to another group. However, the application has not moved the user to the configured promotion group.
http://postimg.cc/kVftSC07
Posted
Thanks for your attention.
I am impatiently waiting for the solution as I have stopped the development of my project until I can solve this problem.
Posted (edited)
I am absolutely grateful for the interest and diligence you have shown in solving the problem. You are certainly a great professional, but above all, you are a good person, and I appreciate that very much.
It looks like the application is now working as expected.
One more thing: How could I hide the direct referral link that appears after the settings button?
I don't want users to use the direct links. Only the personal invitations.
Thank you very much for your help
Edited by McPearse
Posted
Thanks for these kind words, really appreciate it.
Set it in this mode:
Is this what you wanted to achieve?
Posted
I have done what you have indicated, but that option, only changes the place where the link appears. Now it appears in the header of the invitation sending page:
http://postimg.cc/nCKkZd2t
But I need to completely hide that link, so that forum members use only personal invitations.
Posted
OK, so you need to strip it from the source code. Are you familiar and OK with manually editing the files/theme? I'll provide instruction then.
  • 3 weeks later...
Posted
El 9/10/2023 a las 10:59, DawPi dijo:
Bien, entonces debes eliminarlo del código fuente. ¿Está familiarizado y está de acuerdo con la edición manual de archivos/temas? Entonces daré instrucciones.
Please excuse me.
A health complication has kept me away from the project for a few weeks and I have not been able to attend to my pending matters. Please excuse me.
Yes, please, I agree to modify the source code. I await your instructions.
Thank you for everything and again I apologize for the wait.
  • 2 weeks later...
Posted
Ustawiłem tryb polecenia na "invite only", przekierowanie po kliknięciu w link jest na stronę rejestracji.
Niestety, po kliknięciu w link z maila, zaproszeni widzą formularz logowania, a po kliknięciu "zarejestruj się" i wprowadzeniu daty urodzenia dostają komunikat błędu o braku zaproszenia.
Tak samo wygląda sytuacja po podaniu linku zapraszającego
Posted
Tak ustawione?
Ten kod pojawia się kiedy nie wykryto pliku cookie przy trybie Invite Only.
		/* Invite mode only? */
		if ( ( \IPS\Settings::i()->dp41_rsystem_invite_type == 'invite' ) && ( ! isset( \IPS\Request::i()->cookie['dp3_rs_invite_reff_hash'] ) || ( \IPS\Request::i()->cookie['dp3_rs_invite_reff_hash'] == '-' ) || ! \IPS\Request::i()->cookie['dp3_rs_invite_reff_hash'] ) )
			\IPS\Output::i()->error( 'rsystem_invite_must_be_invited_error', 'RSYSTEM_026', 403, '' );
Sprawdźmy:
Jak to dokładnie testujesz? Jaka wersja forum?
Posted
OK, a pliki cookie po kliknięciu w tej URL się zapisują na przeglądarce? Bo tam jakąś blokadę włączyłeś.
Widziałeś, że na moim filmie wszystko działa.
W razie dalszych problemów musiałbym do tego zajrzeć od środka.
Posted
To tryb incognito, z drugiej przeglądarki bez trybu też nie zapisuje ciacha, tutaj jedyne ciacha jakie się odkładają po wejściu z linku:
Posted
@ownede. masz włączone wymuszenie logowania dla gości, bez dostępu do forum. Skrypt nie może sprawdzić i zapisać cookies, bo nie dopuszcza do tego właśnie to ustawienie. Spróbuj je wyłączyć i powinno działać.
Możesz np. gościom w ich uprawnieniach wyłączyć widoczność forum i zastosować jakiś fajny widget zachęcający do rejestracji.
Create an account
Register a new account
Sign in
Sign In Now
  • Recently Browsing   0 members
    • No registered users viewing this page.
  • Create New...
Important Information
