Subfora jako drzewo z 3 pozycjami w wierszu
  • Odpowiedzi 71
  • Dodano
  • Ostatniej odpowiedzi
Top użytkownicy w tym temacie
Opublikowane grafiki
A tak:
				$i=0;
			$subforum = "<table width='100%'><tr>";
			foreach($forum_data['subforums'] as $k)
				$i++;
				$subforum .= "<td width='40%' align='left' valign='top'>".$k."</td>";
				if($i % 3 == 0)
					$subforum .= "</tr>\n<tr>";
			$subforum .= '</tr></table>';
			$forum_data['show_subforums'] = $this->ipsclass->compiled_templates['skin_boards']->show_subforum_all_links( $subforum );
A tak:
				$i=0;
				$i++;
				if($i % 3 == 0)
Ano tak działa! Wielkie dzięki, trochę to było męczące pewnie, ale do czegoś doszliśmy :)
Is this sub forum decoration you use on this forum or not ?? the one on this forum looks great .. could someone tell me how to set it on my forum ??
Hello gami! ;)
I use (IH23) Subforum Indicator v1.1 mod with this small changes.. ;)
I did all like you are .. but something went wrong .. img is after subforum name .. not in front ?! what I did wrong ?? and can I set diferent link img to put som smaller img .. the one I use on my forum is too big ??
Edytowane przez gami
Must be a typo in instructions clearly say after .. but nevermind .. What about replacing img ?? it's to big for subforums .. but if I set some img like you are it's to small forum topics ?!
Just replace this image on ftp with another img. ;) Simply.
Yes that would be simple .. but I don't wont this image to be the same as f_norm.gif or f_norm_no.gif .. If I used small one it looks good on board index .. but not good in forum topics ..
Grr, gish, you're right! ;)
I add some new macros and change in class_forums.php file this code:
if ($img == '<{C_ON}>' || $img == '<{C_ON_CAT}>')
					$img = '<{B_NEW}>';
				else if ($img == '<{C_OFF}>' || $img == '<{C_OFF_CAT}>')
					$img = '<{B_NORM}>';
				else if ($img == '<{C_LOCKED}>')
					$img = '<{B_HOT_NN}>';
				else if ($img == '<{C_ON_RES}>')
					$img = '<{B_HOT_DOT}>';
				else if ($img == '<{C_OFF_RES}>')
					$img = '<{B_HOT_NN_DOT}>';
To:
					$img = '<{DP23INDON}>';
					$img = '<{DP23INDOF}>';
And then add DP23INDON and DP23INDOF macros with my own images! ;)
Jak zmniejszyszyć odległość miedzy tymi sybforami ? bo mi troche forum sie rozjechało...
  • 3 miesiące temu...
A ja dostaje taki błąd :
Parse error: syntax error, unexpected '}' in /home/download/www/sources/classes/class_forums.php on line 962
Mimo że przeczytałem ten temat od deski do deski rozwiązania nie znalazłem
