Panowie - jak dodać drugie menu rozsuwane w skinie velvet blue? W kodzie jest coś takiego
<!-- menu -->
					  <li id="dropdown_1" class="left"><span><a href="#">coś <img src="{style_images_url}/_custom/tabs-submenu_arrow.png" class="sb-dropdown_arrow" /></a></span>
   <ul>
   <li><a href="http:/???" title="???"><img src="{style_images_url}/_custom/strzalka.png"  />???l</a></li>
   <li><a href="http://???" title="???"><img src="{style_images_url}/_custom/strzalka.png" /> ???</a></li>
   </ul>
  </li>
  <!--  menu koniec -->
Po skopiowaniu tego kodu drugie menu nie wysuwa się. Zawsze tylko jedno. Proszę o pomoc.
<div id='header'>
<div id='branding'>
 <if test="brandingBar:|:method_exists( $this->registry->output->getTemplate( $this->registry->getCurrentApplication() . '_global' ), 'overwriteHeader' )">
  {parse template="overwriteHeader" group="{current_app}_global" params=""}
 <else />
  {parse template="defaultHeader" group="global" params=""}
<div id='primary_nav'>
 <ul>
  <if test="showhomeurl:|:$this->settings['home_url']">
  {parse variable="forumActive" default="" oncondition="IPS_APP_COMPONENT == 'forums'" value="active"}
  {parse variable="membersActive" default="" oncondition="IPS_APP_COMPONENT == 'members'" value="active"}
  {parse variable="helpActive" default="" oncondition="IPS_APP_COMPONENT == 'core' AND $this->request['module'] == 'help'" value="active"}
  <if test="!ipsRegistry::$applications['forums']['app_hide_tab']"><li id='nav_discussion' class='left {parse variable="forumActive"}'><a href='{parse url="act=idx" seotitle="false" base="public"}' title='{$this->lang->words['go_to_discussion']}'>{$this->lang->words['discussion']}</a></li></if>
  <if test="!ipsRegistry::$applications['members']['app_hide_tab']"><li id='nav_members' class='left {parse variable="membersActive"}'><a href='{parse url="app=members" base="public" template="members_list" seotitle="false"}' title='{$this->lang->words['go_to_memberlist']}'>{$this->lang->words['tb_mlist']}</a></li></if>
  <if test="applicationsloop:|:is_array($header_items['applications']) AND count($header_items['applications'])">
   <foreach loop="applications:$header_items['applications'] as $data">
	<if test="showingapp:|:$data['app_show']">
	 {parse variable="appActive" default="" oncondition="$data['app_active']" value="active"}
	 <li id='nav_app_{$data['app_dir']}' class="left {parse variable="appActive"}"><a href='{parse url="{$data['app_link']}" seotitle="false" base="public"}' title='{parse expression="sprintf( $this->lang->words['go_to_prefix'], IPSLib::getAppTitle($data['app_dir']) )"}'>{IPSLib::getAppTitle($data['app_dir'])}</a></li>
   </foreach>
  <!-- wysuwane menu -->
					  <li id="dropdown_1" class="left"><span><a href="#">??? <img src="http://forum.invisionize.pl/public/style_images/master/_custom/tabs-submenu_arrow.png" class="sb-dropdown_arrow" /></a></span>
   <ul>
   <li><a href="???" title="???"><img src="http://forum.invisionize.pl/public/style_images/master/_custom/strzalka.png"  />???l</a></li>
   <li><a href="???" title="???"><img src="http://forum.invisionize.pl/public/style_images/master/_custom/strzalka.png" />???</a></li>
   </ul>
  </li>
  <!-- wysuwane menu koniec -->
<!-- wysuwane menu 2-->
   <ul>
   <li><a href="???" title="???"><img src="http://forum.invisionize.pl/public/style_images/master/_custom/strzalka.png"  /> ???</a></li>
   <li><a href="???l" title="???"><img src="http://forum.invisionize.pl/public/style_images/master/_custom/strzalka.png" /> ???l</a></li>
<li><a href=???l" title="???"><img src="http://forum.invisionize.pl/public/style_images/master/_custom/strzalka.png" /> ???</a></li>
</ul>
  </li>
<!-- wysuwane menu koniec 2 -->
<!-- wysuwane menu 3-->
   <ul>
   <li><a href="???" title="???"><img src="http://forum.invisionize.pl/public/style_images/master/_custom/strzalka.png"/> O nas</a></li>
<li><a href="???" title="???"><img src="http://forum.invisionize.pl/public/style_images/master/_custom/strzalka.png"  /> test</a></li>
</ul>
  </li>
<!-- wysuwane menu koniec 3-->
</ul>
  <div class="clear"></div>
Edytowane przez czarnyodyniec
Nie dam bo zaraz będziecie besztać, że styl przerobiłem. A ma całkiem inną kolorystyke niż oryginalny. W załączniku pliki js.
Wydaje mi się, że tu może być pies pogrzebany ale kompletnie się na tym nie znam.
Desktop.rar
Połowa użytkowników IPB nie zna. A i tak korzysta z międzynarodowych supportów, posługując się GT lub własnymi podstawami. Poza tym w tym to akurat możemy mu pomóc:
Hey,
I'd like to add another dropdown menu into my primary navigation bar in my Velvet Blue skin. I have found the following code:
and tried to duplicate it with no luck as the secondary menu was inactive. Is there any quick fix to my issue?
  • Lubię to 2
