Problem ze spolszczeniem
Przejdź do rozwiązania Rozwiązane przez d3eeex,
Mam problem wgrałem wszystko jak w instrukcjach i brakuje polskich znaków oraz gdy klikam w APLIKACJE --> Localize Board --->Aktualizuj wszystko  There appears to be an error with the database.
Co w takim wypadku należy zrobić ?
 Date: Tue, 13 Jan 2015 23:27:45 +0000
 Error: 1267 - Illegal mix of collations (latin1_swedish_ci,IMPLICIT) and (latin2_general_ci,COERCIBLE) for operation '='
 IP Address: 82.160.174.5 - /admin/index.php?adsess=2bb78b84ff06dcb9bb37165d05743b08&app=updatemodules&module=dashboard&section=dashboard
 mySQL query error: SELECT id FROM faq WHERE app='core' AND title = 'Kontakt z zespołem moderacyjnym'
 | admin/applications_addon/other/updatemodules/modules_admin/dashboard/dashboard.php| [admin_core_tools_help].helpFilesXMLImport_app                                | 199               |
 | admin/applications_addon/other/updatemodules/modules_admin/dashboard/dashboard.php| [admin_updatemodules_dashboard_dashboard].doRebuildAll                        | 78                |
 | admin/sources/base/ipsController.php                                       | [admin_updatemodules_dashboard_dashboard].doExecute                           | 306               |
 Date: Sat, 10 Jan 2015 14:12:28 +0000
 IP Address: 82.160.174.5 - /admin/index.php?adsess=2c10e070fe0e753979297868ab3e85a4&app=updatemodules&module=dashboard&section=dashboard
 Date: Sat, 10 Jan 2015 14:12:47 +0000
 Date: Sat, 10 Jan 2015 14:13:49 +0000
 Date: Sat, 10 Jan 2015 14:14:23 +0000
 Date: Sat, 10 Jan 2015 14:17:27 +0000
 Date: Sat, 10 Jan 2015 14:21:25 +0000
 Date: Sat, 10 Jan 2015 14:24:36 +0000
 Date: Sat, 10 Jan 2015 14:26:09 +0000
 Date: Sat, 10 Jan 2015 14:27:37 +0000
 Date: Sat, 10 Jan 2015 14:39:13 +0000
 Date: Sat, 10 Jan 2015 14:44:35 +0000
 Date: Sat, 10 Jan 2015 15:02:26 +0000
 Date: Sat, 10 Jan 2015 15:10:15 +0000
 IP Address: 82.160.174.5 - /index.php?/forum/2-a-test-forum/
 mySQL query error: SELECT t.*,xxx.* FROM topics t  LEFT JOIN core_tags_cache xxx ON ( xxx.tag_cache_key=MD5(CONCAT('forums',';','topics',';',t.tid)) )   WHERE t.forum_id=2 AND t.pinned IN (0,1) AND ( t.approved IN (1,0,-1) ) ORDER BY t.pinned DESC,  t.last_post DESC LIMIT 0,30
 | admin/applications/forums/modules_public/forums/forums.php                 | [public_forums_forums_forums].renderForum                                     | 457               |
 | admin/applications/forums/modules_public/forums/forums.php                 | [public_forums_forums_forums].showForum                                       | 147               |
 | admin/sources/base/ipsController.php                                       | [public_forums_forums_forums].doExecute                                       | 306               |
 Date: Sat, 10 Jan 2015 15:27:15 +0000
 Date: Sat, 10 Jan 2015 15:33:15 +0000
 Date: Sat, 10 Jan 2015 15:33:17 +0000
 Date: Sat, 10 Jan 2015 15:33:20 +0000
 Date: Sat, 10 Jan 2015 15:33:24 +0000
 Date: Sat, 10 Jan 2015 15:33:25 +0000
 Date: Sat, 10 Jan 2015 15:33:27 +0000
 Date: Sat, 10 Jan 2015 15:38:52 +0000
 IP Address: 82.160.174.5 - /admin/index.php?adsess=3485f74973e9cc561d8a32cc03c0dc36&app=updatemodules&module=dashboard&section=dashboard
 Date: Sat, 10 Jan 2015 18:11:09 +0000
 IP Address: 82.160.174.5 - /admin/index.php?adsess=0cc8c168e1ba1c8580d15e9a2e58e8a7&app=updatemodules&module=dashboard&section=dashboard
 Date: Tue, 13 Jan 2015 20:32:51 +0000
 IP Address: 82.160.174.5 - /admin/index.php?adsess=2887711cf346f261e27c0aebe4d1bd4d&app=updatemodules&module=dashboard&section=dashboard
 Date: Tue, 13 Jan 2015 20:35:20 +0000
 Date: Tue, 13 Jan 2015 21:39:21 +0000
 IP Address: 82.160.174.5 - /admin/index.php?adsess=9063a38a2668ca22f7a15f7e9b6edde4&app=updatemodules&module=dashboard&section=dashboard
 Date: Tue, 13 Jan 2015 22:20:53 +0000
 Date: Tue, 13 Jan 2015 23:16:24 +0000
To pokazują logi.
Sorki za błąd wyżej który tak bije w oczy :)
Masz pomieszane kodowanie znaków w bazie SQL latin1_swedish_ci oraz latin2_general_ci ... Pisałem wyżej, użyj konwertera od IPS i napraw to. Ale najpierw zrób backup bazy SQL.
Juz chyba pomieszałem jak się da. Pierw usunąć te wpisy Latin2 z classDB ? Którego konwertera użyć ? ogólnie mógł bym baze od nowa zainstalować ( jeśli będzie łatwiej )bo na forum jeszcze nic nie ma.
Almost there!
The database has now been converted!
Conversion took 0 minute(s) and 39 seconds.
You can now test the conversion by editing conf_global.php to add $INFO['sql_charset'] = 'utf8'; and to change your$INFO['sql_tbl_prefix']
to: $INFO['sql_tbl_prefix'] = 'x_utf_';
Ok zrobione. Czy w pliku conf_global.php dodać utf8 czy latin2 tak jak zostało to dodane według innej instrukcji ?
Zmieniłem jak napisane, podmieniłem powtórnie index.php na stary i ten bład wyskakuje .
 Driver Error
You can try to refresh the page by clicking here
Edytowane przez d3eeex
 Date: Wed, 14 Jan 2015 14:13:19 +0000
 Error: 1146 - Table 'hpvwiruskpforum.x_utf_cache_store' doesn't exist
 mySQL query error: SELECT * FROM x_utf_cache_store WHERE cs_key IN ( 'systemvars','login_methods','vnums','app_cache','navigation_tabs','module_cache','hooks','useragents','useragentgroups','skinsets','outputformats','skin_remap','group_cache','settings','lang_data','banfilters','stats','badwords','bbcode','mediatag','profilefields','rss_output_cache','rss_export','meta_tags','ipseo_acronyms','attachtypes','multimod','moderators','announcements','report_cache','report_plugins','ranks','reputation_levels','chatting','birthdays','calendar_events','calendars','support_staff','support_departments','support_statuses','donation_goals','blog_stats','blogmods','idm_cats','idm_mods' )
 | admin/sources/base/ipsRegistry.php                                         | [ips_CacheRegistry]._loadCaches                                               | 3047              |
 | admin/sources/base/ipsRegistry.php                                         | [ips_CacheRegistry].init                                                      | 2841              |
 | admin/sources/base/ipsRegistry.php                                         | [ips_CacheRegistry].instance                                                  | 580               |
To co mogę z tym zrobić na tym etapie bo juz nie mam pojęcia kompletnego do czego znowu wrócić i próbować naprawić to kodowanie.
Hmm jeszcze nie zacząłem instalacji na nowo ale tam w plikach classDbMysqlClient zmieniłem z latin2 na utf8, wrzuciałem znowu converter i poszło na tyle że forum z znowu działa i tym razem mogłem W LOCALIZE BOARD wcisnąć aktualizuj wszystko i poszło Wszystkie elementy zosta??y przebudowane!
Mimo to dalej nie ma polskich znaków ale być może jestem bliżej rozwiązania problemu ?
 Date: Thu, 15 Jan 2015 00:06:13 +0000
 Error: 1146 - Table fpforum.x_utf_cache_store' doesn't exist
Nie wiem po co grzebiesz w plikach skryptu. Miałeś zmienić kodowanie znaków w bazie SQL w PMA. Przejrzyj uważnie wszystkie tabele i zobacz jakie mają kodowanie. Jeśli inne niż potrzeba, napraw je.
Chciałem sprawdzić czy po zmianie z latin2 na utf8 coś sie zmieni. Ok to teraz mam przywrócić jak było na latin 2 w  classDbMysqlClient ?
W PMA z grubsza widzę ze wszystko jest w strukturze ustawione na utf8_unicode_ci tak ma być czy wybrać inną opcję  ?
Dzisiaj z 2h ręcznie zmieniałem w każdej tabeli w bazie danych kodowanie z latin1_swedish_ci na utf8_polish_ci.
ze sql error błędy następujące a polskich znaków dalej nie ma.
 Error: 1146 - Table 'pforum.x_utf_cache_store' doesn't exist
Co może być problem teraz ?
