Problem ze spolszczeniem
Przejdź do rozwiązania Rozwiązane przez d3eeex,
Co zmienić w conf_globa.php ?
$INFO['sql_driver'] = 'mysql';
$INFO['sql_host'] = 'xxxmysql.db';
$INFO['sql_database'] = 'xxx';
$INFO['sql_user'] = 'xxx;
$INFO['sql_pass'] = 'xxx';
$INFO['sql_tbl_prefix'] = 'x_utf_';
$INFO['sql_debug'] = '0';
$INFO['sql_charset'] = 'utf8';
$INFO['board_start'] = '1420814291';
$INFO['installed'] = '1';
$INFO['php_ext'] = 'php';
$INFO['safe_mode'] = '0';
$INFO['board_url'] = 'http://xxx.pl';
$INFO['banned_group'] = '5';
$INFO['admin_group'] = '4';
$INFO['guest_group'] = '2';
$INFO['member_group'] = '3';
$INFO['auth_group'] = '1';
$INFO['use_friendly_urls'] = '1';
$INFO['_jsDebug'] = '0';
$INFO['mysql_tbl_type'] = 'MyISAM';
define('IN_DEV', 0);
/* Remote archive DB - complete these details if you\'re using a remote DB for the post archive.
   If content has already been archived in the local DB, this will need transferring and will not be done automatically. */
$INFO['archive_remote_sql_host'] = '';
$INFO['archive_remote_sql_database'] = '';
$INFO['archive_remote_sql_user'] = '';
$INFO['archive_remote_sql_pass'] = '';
$INFO['archive_remote_sql_charset'] = '';
Sory nie wiedziałem że trzeba ponownie zmienić na $INFO['sql_tbl_prefix'] = '';
Teraz cache wygląda tak :
 Date: Thu, 15 Jan 2015 00:06:13 +0000
 Error: 1146 - Table 'hforum.x_utf_cache_store' doesn't exist
 IP Address: 82.160.174.5 - /
 mySQL query error: SELECT * FROM x_utf_cache_store WHERE cs_key IN ( 'systemvars','login_methods','vnums','app_cache','navigation_tabs','module_cache','hooks','useragents','useragentgroups','skinsets','outputformats','skin_remap','group_cache','settings','lang_data','banfilters','stats','badwords','bbcode','mediatag','profilefields','rss_output_cache','rss_export','meta_tags','ipseo_acronyms','attachtypes','multimod','moderators','announcements','report_cache','report_plugins','ranks','reputation_levels','chatting','birthdays','calendar_events','calendars','support_staff','support_departments','support_statuses','donation_goals','blog_stats','blogmods','idm_cats','idm_mods' )
 | admin/sources/base/ipsRegistry.php                                         | [ips_CacheRegistry]._loadCaches                                               | 3047              |
 | admin/sources/base/ipsRegistry.php                                         | [ips_CacheRegistry].init                                                      | 2841              |
 | admin/sources/base/ipsRegistry.php                                         | [ips_CacheRegistry].instance                                                  | 580               |
W czym dalej problem ?
Jeśli zostawiam  $INFO['sql_tbl_prefix'] = ''; to dalej bład w cache, jeśli wpiszę  $INFO['sql_tbl_prefix'] = ''utf8_polish_ci" lub  $INFO['sql_tbl_prefix'] = ''utf8_unicode_ci" to wywala mi Wystąpił problem z bazą danych.
Jeśli widzisz tę stronę to znaczy, że wystąpił problem z dostępem do bazy danych. Niekiedy jest to tymczasowy błąd i po krótkim czasie powinien ustąpić kiedy odświeży się stronę (F5). W innym przypadku błąd musi zostać sprawdzony oraz naprawiony przez administratora forum.
Jeśli to ty jesteś tym administratorem możesz skorzystać z poradnika i spróbować naprawić błąd na własną rękę lub też skorzystać z pomocy bardziej doświadczonych administratorów.
Możesz wykonać próbę odświeżenia tej strony klikając tutaj
Przy $INFO['sql_tbl_prefix'] = 'orig_'; błąd Your settings could not be read by IP.Board. This is a fatal error and IP.Board cannot function while this issue persists.
Przy pustym prefixie $INFO['sql_tbl_prefix'] = '';  Dalej to samo wywala . Ale forum działa ( bez pl znaków ). Tylko nie wiem czemu bład last cache jest z z godziny 15:14 jęsli teraz zmieniłem ustawienia.
 Date: Sat, 17 Jan 2015 15:14:12 +0000
 Error: 1146 - Table 'xxxforum.xxxforum_utf8cache_store' doesn't exist
 IP Address: 82.160.174.5 - /index.php
 mySQL query error: SELECT * FROM xxxorum_utf8cache_store WHERE cs_key IN ( 'systemvars','login_methods','vnums','app_cache','navigation_tabs','module_cache','hooks','useragents','useragentgroups','skinsets','outputformats','skin_remap','group_cache','settings','lang_data','banfilters','stats','badwords','bbcode','mediatag','profilefields','rss_output_cache','rss_export','meta_tags','ipseo_acronyms','attachtypes','multimod','moderators','announcements','report_cache','report_plugins','ranks','reputation_levels','chatting','birthdays','calendar_events','calendars','support_staff','support_departments','support_statuses','donation_goals','blog_stats','blogmods','idm_cats','idm_mods' )
Edytowane przez d3eeex
http://forum.invisionize.pl/topic/41861-po-przeniesieniu-forum-your-settings-could-not-be-read-by-ipboard/
Mogł by ktoś zrobić upload z plików potrzebnych do upgrade ?
Nie mogę tego znaleźć... potem przejdę do kroku Wrzuć do /admin/ i uruchom site.com/admin/upgradeFinish.
Przeglądając paczkę pobraną z CA nie wiem czy u mnie brakuję czy szukam w złych katalogach. Daje screeny niżej :
----> główny katalog
----> Folder admin
I na końcu folder admin/ upgrade
Tu akurat screeny z plików  wersji 4 beta ale w 3.4.7 także tego brakuje.
Po ściągnięciu ponownie plików z CA
Brakuje katalogu tools
Więc juz nie mam kompletnie pojęcia skąd to wziąć .
Ok temat do zamknięcia. Co krok to były błędy jakieś.  Z racji że forum nie miało jeszcze ani jednego użytkownika, postanowiłem wszystko zainstalować od nowa i wszystko działa jak powinno. Są polskie znaki.
Dzięki za pomoc.
