Zgodnie z poradą zainstalowałem najnowszą wersje IPB. Jednak po niedługim czasie po zainstalowaniu wyskakuje mi błąd i nie chce się pokazać nawet pierwsza strona.
Błąd wygląda tak:
Znalazłem też plik sql_error_log....... Jego zawartość wygląda tak:
Date: Wed, 11 Nov 2009 22:22:28 +0000
Error Number: 1142
Error: UPDATE command denied to user 'netgamer_25'@'77.55.73.131' for table 'ipf2_members' - check your database quota
IP Address: 83.6.193.41
Page: /DS/forum_ipb/
Debug: array (
 1 =>
 array (
   'file' => '/home/netgamer/ftp/DS/forum_ipb/ips_kernel/classDb.php',
   'line' => 1095,
   'function' => 'query',
   'class' => 'db_driver_mysql',
 3 =>
 array (
   'file' => '/home/netgamer/ftp/DS/forum_ipb/admin/sources/base/core.php',
   'line' => 5653,
   'function' => 'update',
   'class' => 'db_main_mysql',
 4 =>
 array (
   'file' => '/home/netgamer/ftp/DS/forum_ipb/admin/sources/classes/session/publicSessions.php',
   'line' => 930,
   'function' => 'save',
   'class' => 'IPSMember',
 5 =>
 array (
   'line' => 472,
   'function' => '_createMemberSession',
   'class' => 'publicSessions',
 6 =>
 array (
   'file' => '/home/netgamer/ftp/DS/forum_ipb/admin/sources/base/ipsRegistry.php',
   'line' => 3242,
   'function' => '__construct',
 7 =>
 array (
   'line' => 3083,
   'function' => 'init',
   'class' => 'ips_MemberRegistry',
 8 =>
 array (
   'line' => 514,
   'function' => 'instance',
mySQL query error: UPDATE ipf2_members SET login_anonymous='0&1',last_visit=1257942704,last_activity=1257978147,member_login_key_expire=1258582948 WHERE member_id=1
Date: Wed, 11 Nov 2009 22:22:29 +0000
Error Number: 1142
Debug: array (
 1 =>
 array (
   'line' => 1095,
 3 =>
 array (
   'line' => 5653,
 4 =>
 array (
   'line' => 930,
 5 =>
 array (
   'line' => 472,
 6 =>
 array (
   'line' => 3242,
 7 =>
 array (
   'line' => 3083,
 8 =>
 array (
   'line' => 514,
mySQL query error: UPDATE ipf2_members SET login_anonymous='0&1',last_visit=1257942704,last_activity=1257978149,member_login_key_expire=1258582949 WHERE member_id=1
Możliwe że popełniłem jakiś błąd i jest to moja wina. Lecz proszę o pomoc w rozwiązaniu tegoż problemu gdyż jest to dla mnie ważne.
Prosił bym też o podanie jakiegoś downloadu by pobrać IPB 3.0.4, możliwe że źrudło z jakiego pobrałem nie jest 100% pewne i pliki zawierały błąd.
Pozdrawiam.
Edytowane przez Cleric
Heart breackers and life takers...
Wyczerpał się limit rozmiaru bazy. Zmień w panelu serwera maksymalny rozmiar bazy danych i problem zniknie.
DawPi, powiem szczeże. Jestem laikiem w te klocki. Wcześniej operowałem phpbb a i tak z baz danych nic nie umiem. Czy mógł byś mi to w skrucie wyjaśnić?
Proszę Cię - jak robisz błędy ortograficzne to przepuszczaj swoje posty przez Worda, albo zmień przeglądarkę na Firefoxa, który podkreśla błędy, bo to aż razi w oczy.
Odnośnie problemu - to nie ja mam Ci to wyjaśniać tylko administrator Twojego serwera. Przecież zapłaciłeś za serwer to masz prawo wymagać takich informacji.
Przepraszam za błędy. Wiem że je robię i są karygodne ale zawsze uważałem że liczy się treść. Ale mniejsza o to.
Mam pytanie, czy wie Pan może ile średnio zajmuje baza IPB 3.0.4 tuż po za instalowaniu?
I ponawiam pytanie na temat downloadu skryptu, chyba że ponowne wgrywanie jest zbędne lub moje pytanie jest nie na miejscu to przepraszam.
A jeszcze wcześniej kupić u niego. :)
Oczywiście, że liczy się treść, ale przyjemniej się czyta, jeśli tekst jest napisany poprawnie, zarówno stylistycznie jak merytorycznie i gramatycznie. Nieprawdaż?
Zgodzę się, stylistyka, ortografia itp są ważne. Ale wracając do tematu.
Teoretycznie z tego co mi wiadomo przestrzeń przewidziana na bazę jest nie ograniczona.
Co do downloadu to owszem najlepiej kupić itp. Tyle że ja muszę najpierw postawić forum potem zostanie wykupiona licencja. Nie ja płace więc nie ode mnie to zależy.
Czy jest inna droga?
Dziękuje obu Panom za pomoc, na pewno nie z jednym pytaniem napiszę.
Mam nadzieję że otrzymam potrzebną mi pomoc.
Pozdrawiam.
(temat do zamknięcia)
