(Pav31) Tags System
Pavulon
Hi pavulon
Sorry i write in english
i'm very interested at this mod.
But i want to know (if possible)
-did can give a problem in future if is not compatible with next version of IPB?
-what is the SEO improvement using this mod?
-when you think is good to use this mod?
Safe mode on can be a problem? (my test board)
Because i have installed this app, good installation, i see all setting in acp, all is active. but in front end i have this error [#6 PTS] Nie znaleziono tagów and in news topic i dont see the field
i think that safe mode is a problem, because in my local installation has worked
:wyglad:
Date: Fri, 10 Sep 2010 09:44:50 +0000
Error Number: 1054
Error: Unknown column 'tag_hidden' in 'where clause'
IP Address: 10.24.10.17
Page: /
Debug: array (
 1 =>
 array (
   'file' => '/home/www/forum/ips_kernel/classDb.php',
   'line' => 988,
   'function' => 'query',
   'class' => 'db_driver_mysql',
 3 =>
 array (
   'file' => '/home/www/forum/admin_storajs_niubi/sources/classes/output/publicOutput.php',
   'line' => 2795,
   'function' => 'getOutput',
   'class' => 'TagssSidebar',
 4 =>
 array (
   'line' => 2123,
   'function' => 'templateHooks',
   'class' => 'output',
 5 =>
 array (
   'file' => '/home/www/forum/admin_storajs_niubi/applications/forums/modules_public/forums/boards.php',
   'line' => 120,
   'function' => 'sendOutput',
 6 =>
 array (
   'file' => '/home/www/forum/hooks/dp30CustomMetaTags_8c28a876ad208710766f9d97ca7030a9.php',
   'line' => 69,
   'function' => 'doExecute',
   'class' => 'public_forums_forums_boards',
 7 =>
 array (
   'file' => '/home/www/forum/admin_storajs_niubi/sources/base/ipsController.php',
   'line' => 291,
   'class' => 'dp30CustomMetaTags',
mySQL query error: SELECT COUNT(tag) as times, tag FROM ibf_tags_index WHERE app='forums' AND tag_hidden=0 GROUP BY tag ORDER BY times DESC LIMIT 0,50
Jesteś pewny, że dobrze zainstalowałeś tę aplikację? Odinstaluj i zainstaluj ją ponownie i daj znać.
Pavulon świetna modyfikacja :wyglad: Mam jednak kilka sugestii mianowicie czy da się zrobić takie rzeczy...
Przycisk "wstaw z posta" można włączyć lub wyłączyć w ustawieniach (dobrze by było np. mieć wybór grup tj. komu się on wyświetla a komu nie)
Ciekawą opcją byłoby także wg. mnie możliwość włączenia ignorowanych (zakazanych) tagów - często jest tak, że np. ktoś wstawia tagi z posta i dodawany jest tag "url" co wg. mnie jest nieraz denerwujące i niepotrzebne :a:
Pozdrawiam i jeszcze raz wielkie THX za modyfikację.
Pavulon, trochę się u mnie ostatnio uspokoiło i wróciłem do prób rozwiązania błędu z 2 strony tego wątku - braku polskich znaków diaktrycznych na forum. Problem występuję na obu moich forach, obu z kodowaniem iso-8859-2 (latin2) i systemem porównań latin2_general_ci (w tabeli tags_index). Mimo tego nadal występuje problem, przykładowo wyświetla się jeĹşdziÄ zamiast jeździł. Jedyna nowa rzecz, którą zauważyłem, to System porównań dla połączenia MySQL: utf8_general_ci oraz Kodowanie napisów dla MySQL: UTF-8. Czy może to mieć związek z problemem, lub jakie rozwiązanie może być najbardziej prawdopodobne? Oba fora są stosunkowo niedługo na IP.Board (jedno około miesiąca, drugie 4 dni) więc nie miałem szans na "namieszanie" w kodzie. Masz może jakiś pomysł?
Jeżeli ktoś jest zainteresowany drobną aktualizacją to polecam: http://amxx.pl/public/js/tagss.js
Aczkolwiek to tylko ignorowanie zawartości tagów url i img, ale zanim wydam kompletną aktualizację to dobre i to.
A co do twojego problemy croco, to będę chyba musiał postawić forum na lokalu z takim kodowaniem :/
Swoją drogą skoro to młode serwisy to nie wiem czemu nie są na UTF-8 tylko na latinie :)
Jedno przejście na utf i koniec z problemami kodowania...
croco, przesiedziałem nad testami ISO-8859-2 od wczoraj i mam złą wiadomość.
Albo IPS nie dopracowało klasy tags lub innej albo sam nie wiem.
Problem polskich znaków w tagach występuje już w blogach(gdzie tagi są oryginalnie).
Nawet ustawienie ISO-8859-1 daje lepszy efekt.
Czyli nie istnieje szansa poprawnego działania tej modyfikacji na forach z kodowaniem iso-8859-2, tak? Jedynym wyjściem jest konwersja na UTF-8, czy może jest szansa że ewentualny błąd ze strony IPS zostanie wyeliminowany w przyszłości (najbliższej)?
