Subfora - Mały Problem.
GoDLooK
Przejdź do rozwiązania Rozwiązane przez GoDLooK,
tezz, wiem może wydawać się wam to śmieszne ale nie dam rady tego zrobić jak byś mógł wytłumaczyć mi jaśniej.
boardIndexTemplate:
{parse js_module="board"}
{parse variable="sidebar_enabled" default="$show_side_blocks"}
<if test="boardIndexTop:|:true"></if>
<div id='board_index' class='ipsLayout <if test="sideBarEnabledL:|:$this->templateVars['sidebar_enabled']">ipsLayout_withright</if> ipsLayout_largeright clearfix <if test="sidebarclosed:|:IPSCookie::get('hide_sidebar') == '1'">no_sidebar</if>'>
	<div id='categories' class='ipsLayout_content clearfix'>
	<!-- CATS AND FORUMS -->
		<if test="cats_forums:|:is_array( $cat_data ) AND count( $cat_data )">
			<foreach loop="categories:$cat_data as $_data">
				<if test="cat_has_forums:|:is_array( $_data['forum_data'] ) AND count( $_data['forum_data'] )">
					<div id='category_{$_data['cat_data']['id']}' class='category_block block_wrap'>
						<h3 class='maintitle'>
							<a class='toggle right' href='#' title="{parse expression="sprintf( $this->lang->words['toggle_cat'], IPSText::striptags( IPSText::htmlspecialchars($_data['cat_data']['name'] ) ) )"}">{parse expression="sprintf( $this->lang->words['toggle_cat'], $_data['cat_data']['name'] )"}</a> <a href="{parse url="showforum={$_data['cat_data']['id']}" seotitle="{$_data['cat_data']['name_seo']}" template="showforum" base="public"}" title='{parse expression="sprintf( $this->lang->words['view_cat'], IPSText::striptags( IPSText::htmlspecialchars($_data['cat_data']['name'] ) ) )"}'>{$_data['cat_data']['name']}</a>
						</h3>
						<div class='ipsBox table_wrap removeDefault'>
							<div class='ipsBox_container'>
								<table class='ipb_table' summary="{$this->lang->words['forums_in_cat']} '{$_data['cat_data']['name']}'">
									<tr class='header'>
										<th scope='col' class='col_c_icon'> </th>
										<th scope='col' class='col_c_forum'>{$this->lang->words['cat_name']}</th>
										<th scope='col' class='col_c_stats stats'>{$this->lang->words['stats']}</th>
										<if test="canSeeLastInfoHeader:|:$this->memberData['gbw_view_last_info']"><th scope='col' class='col_c_post'>{$this->lang->words['last_post_info']}</th></if>
									</tr>
									<!-- / CAT HEADER -->
									<foreach loop="forums:$_data['forum_data'] as $forum_id => $forum_data">
										<if test="forumRedirect:|:$forum_data['redirect_on']">
											<tr class='redirect_forum' id='f_{$forum_data['id']}'>
												<td class='col_c_icon'>
													<img src='{$this->settings['img_url']}/f_redirect.png' />
												</td>
												<td <if test="canSeeLastInfoRedirect:|:$this->memberData['gbw_view_last_info']">colspan='2'</if> class='col_c_forum'>
													<h4><a href="{parse url="showforum={$forum_data['id']}" seotitle="{$forum_data['name_seo']}" template="showforum" base="public"}" title='{parse expression="IPSText::striptags( IPSText::htmlspecialchars( $forum_data['name'] ) )"}'>{$forum_data['name']}</a></h4>
													<p class='desc'>{$forum_data['description']}</p>
												</td>
												<td class='desc'>
													<ul class='last_post ipsType_small'>
														<li class='desc lighter'><em>{parse format_number="$forum_data['redirect_hits']"} {$this->lang->words['rd_hits']}</em></li>
													</ul>
												</td>
											</tr>
										<else />
											<tr class='<if test="hasUnreadClass:|:$forum_data['_has_unread']">unread</if>'>
													<if test="hasUnread:|:$forum_data['_has_unread']">
														<a id='forum_img_{$forum_data['id']}' href="{parse url="app=forums&module=forums&section=markasread&marktype=forum&forumid={$forum_data['id']}&returntoforumid={$this->request['f']}&i=1" base="public"}" data-tooltip="{$this->lang->words['bi_markread']}" class='forum_marker'><if test="$forum_data['icon'] != '' AND $forum_data['icon'] !='0'">{$forum_data['icon']}<else /><img src='{$this->settings['img_url']}/f_icon.png' /></if></a>
													<else />
														<if test="$forum_data['icon'] != '' AND $forum_data['icon'] !='0'">{$forum_data['icon']}<else /><img src='{$this->settings['img_url']}/f_icon_read.png' /></if>
												</td>
												<td class='col_c_forum'>
													<h4>
														<if test="hasQueuedAndCanSeeIcon:|:!empty($forum_data['_has_queued_and_can_see_icon'])">
															<a href='{parse url="showforum={$forum_data['id']}&modfilter=unapproved" seotitle="{$forum_data['name_seo']}" template="showforum" base="public"}' title='{$this->lang->words['view_unapproved']}' class='ipsBadge ipsBadge_orange' data-tooltip="{parse expression="sprintf( $this->lang->words['f_queued'], $forum_data['queued_topics'], $forum_data['queued_posts'])"}" style='vertical-align: top'>{$this->lang->words['f_queued_badge']}</a>
														<a href="{parse url="showforum={$forum_data['id']}" seotitle="{$forum_data['name_seo']}" template="showforum" base="public"}" title='{parse expression="IPSText::striptags($forum_data['name'])"}'><if test="$forum_data['_name']">{$forum_data['_name']}<else />{$forum_data['name']}</if></a>
													</h4>
													<if test="showSubForums:|:$forum_data['show_subforums'] AND count( $forum_data['subforums'] ) AND $forum_data['show_subforums']">
														<br />
														<p class='desc __forum_desc ipsType_small'>{$forum_data['description']}</p>
														<ol class='ipsList_inline ipsType_small subforums1' id='subforums_{$forum_data['id']}'>
															<foreach loop="subforums:$forum_data['subforums'] as $__id => $__data">
														</ol>
														<ol class='subforums'>
																<if test="showSubForumsLit:|:$__data[3]"><li class='unread'><else /><li></if>
																	<a href="{parse url="showforum={$__data[0]}" seotitle="{$__data[2]}" template="showforum" base="public"}" title='{$__data[1]}'>{$__data[1]}</a><if test="isNotLast:|: empty($__data[4] )">,</if>
																</li>
															</foreach>
														</ol>
												</td>
												<td class='col_c_stats ipsType_small staty'>
													<ul>
														<li><strong>{$forum_data['topics']}</strong> {$this->lang->words['topics']}</li>
														<li><strong>{$forum_data['posts']}</strong> {$this->lang->words['replies']}</li>
													</ul>
												</td>
												<if test="canSeeLastInfo:|:$this->memberData['gbw_view_last_info']">
												<td class='col_c_post'>
													<if test="hideLastInfo:|:$forum_data['hide_last_info']">
															<li class='desc lighter'><em>{$this->lang->words['f_protected']}</em></li>
														</ul>
													<else />
														<if test="hideTopicInTitle:|:$forum_data['_hide_last_date']">
														{parse template="userSmallPhoto" group="global" params="array('member_id' => $forum_data['last_poster_id'], 'members_seo_name' => $forum_data['seo_last_name'], 'pp_small_photo' => $forum_data['pp_small_photo'], 'alt' => '' )"}
														<else />
														{parse template="userSmallPhoto" group="global" params="array('member_id' => $forum_data['last_poster_id'], 'members_seo_name' => $forum_data['seo_last_name'], 'pp_small_photo' => $forum_data['pp_small_photo'], 'alt' => sprintf( $this->lang->words['bindex_userphoto_alt'], $forum_data['last_title'], $forum_data['members_display_name'] ) )"}
															<if test="!$forum_data['last_id']">
																<li class='desc lighter'><em>{$this->lang->words['f_none']}</em></li>
															<else />
																<li>
																	{$forum_data['last_topic_title']}
																</li>
																<if test="lastPosterID:|:$forum_data['last_poster_id']">
																	<li>{$this->lang->words['by']} {parse template="userHoverCard" group="global" params="$forum_data"}</li>
																<if test="hideDateUrl:|:$forum_data['_hide_last_date']">
																	<li class='desc lighter blend_links'>{parse date="$forum_data['last_post']" format="DATE"}</li>
																<else />
																	<li class='desc lighter blend_links'><a href='{parse url="showtopic={$forum_data['last_id']}&view=getlastpost" base="public" template="showtopic" seotitle="{$forum_data['seo_last_title']}"}' title='{$this->lang->words['view_last_post']}'>{parse date="$forum_data['last_post']" format="DATE"}</a></li>
														</ul>
												</td>
											</tr>
									</foreach>
								</table>
						<br />
			</foreach>
	<if test="sideBarEnabled2:|:$this->templateVars['sidebar_enabled']">
		<div id='index_stats' class='ipsLayout_right clearfix' <if test="sidebarclosed2:|:IPSCookie::get('hide_sidebar') == '1'">style='display: none'</if>>
			<foreach loop="side_blocks:$side_blocks as $block">
				{$block}
			</foreach>
		<a href='#' id='toggle_sidebar' title='{$this->lang->words['toggle_sidebar']}' data-closed="{$this->lang->words['_laquo']}" data-open="×"> </a>
//<![CDATA[
	var markerURL  = ipb.vars['base_url'] + "app=forums&module=ajax&section=markasread&i=1"; // Ajax URL so don't use &
	var unreadIcon = "<img src='{$this->settings['img_url']}/f_icon_read.png' />";
	<if test="markercatforums:|:is_array( $cat_data ) AND count( $cat_data )">
		<foreach loop="markercategories:$cat_data as $_data">
			<if test="markerhasforums:|:is_array( $_data['forum_data'] ) AND count( $_data['forum_data'] )">
				<foreach loop="markerforums:$_data['forum_data'] as $forum_id => $forum_data">
					<if test="markernotredirect:|:!$forum_data['redirect_on']">
						<if test="markerhasunread:|:$forum_data['_has_unread']">
<if test="$this->settings['dp3_fi_mode'] == 'replace'">var unreadIcon = "{$forum_data['icon_read']}";</if>
	ipb.global.registerMarker( "forum_img_{$forum_data['id']}", "{$forum_data['img_new_post']}", markerURL + "&forumid={$forum_data['id']}" );
				</foreach>
		</foreach>
</script>
<h3 id='category_stats' class='maintitle'>
	<a title='Statystyki forum'>{$this->lang->words['board_stats']}</a>
	<span class="right desc">
	<if test="statsLinks:|:1==1"> <!-- Hook point -->
		<a href="{parse url="app=forums&module=extras&section=stats&do=leaders" base="public"}" title="{$this->lang->words['sm_forum_leaders_title']}">{$this->lang->words['sm_forum_leaders']}</a> ·
		<a href="{parse url="app=forums&module=extras&section=stats" base="public"}" title="{$this->lang->words['sm_all_posters_title']}">{$this->lang->words['sm_today_posters']}</a> ·
		<a href="{parse url="app=members&module=list&max_results=20&sort_key=posts&sort_order=desc&filter=ALL" base="public" seotitle="false"}" title="{$this->lang->words['sm_overall_posters_title']}">{$this->lang->words['sm_overall_posters']}</a>
		<if test="reputationEnabled:|:$this->settings['reputation_enabled']">
			 · <a href="{parse url="app=members&module=reputation&section=most" base="public" template="most_liked" seotitle="most_liked"}">
				<if test="reputationType:|:$this->settings['reputation_point_types'] == 'like'">
					{$this->lang->words['most_rep_likes']}
				<else />
					{$this->lang->words['most_rep_rep']}
			</a>
	</span>
</h3>
<div class='table_wrap'>
	<div id='board_statistics' class='category_block statistics clearfix stats_container row2 stats_border'>
		<if test="showTotals:|:$this->settings['show_totals']">
		<div id='stats'>
			<h2>{$this->lang->words['board_stats']}</h2>
			<dl>
				<dt>
					{$this->lang->words['total_posts']}
				</dt>
				<dd>
					{$stats['info']['total_posts']}
				</dd>
				<dt>
					{$this->lang->words['total_members']}
				</dt>
				<dd>
					{$stats['info']['mem_count']}
				</dd>
				<dt>
					{$this->lang->words['newest_member']}
				</dt>
				<dd>
					{IPSMember::makeProfileLink( $stats['info']['last_mem_name'], $stats['info']['last_mem_id'], $stats['info']['last_mem_seo'], 'value' )}
				</dd>
				<dt>
					{$this->lang->words['online_at_once']}
				</dt>
				<dd>
					{$stats['info']['most_online']}<br>
					<span class='extra'>{$stats['info']['most_time']}</span>
				</dd>
				<dt>
				</dt>
				<dd>
				</dd>
			</dl>
		<div id='active_users' class='stats_list'>
			<if test="showActive:|:$this->settings['show_active'] && $this->memberData['gbw_view_online_lists']">
				<h2>
					{parse expression="sprintf( $this->lang->words['online_right_now'], $stats['TOTAL'] )"}
					<span>{$this->lang->words['active_users']}</span><br>
					<span class='desc'>
						{parse expression="sprintf( $this->lang->words['active_users_detail'], $stats['MEMBERS'], $stats['GUESTS'], $stats['ANON'] )"}
						<if test="onlineListEnabled:|:$this->settings['allow_online_list']">  <a href='{parse url="app=members&module=online&sort_order=desc" base="public"}'>({$this->lang->words['online_link']})</a></if>
					</span>
				</h2>
			<if test="activeNames:|:count($stats['NAMES']) && $this->settings['show_active']">
				<p>
					<span class='name'>{parse expression="implode( ",</span> <span class='name'>", $stats['NAMES'] )"}</span>
				</p>
						</h3>
									<tr class='header'>
									</tr>
												</td>
												</td>
												<td class='desc'>
													</ul>
												</td>
											</tr>
										<else />
													<else />
												</td>
													<h4>
													</h4>
														<br />
														</ol>
																</li>
															</foreach>
														</ol>
												</td>
													<ul>
													</ul>
												</td>
														</ul>
													<else />
														<else />
															<else />
																<li>
																</li>
																<else />
														</ul>
												</td>
											</tr>
									</foreach>
								</table>
						<br />
			</foreach>
				{$block}
			</foreach>
//<![CDATA[
				</foreach>
		</foreach>
</script>
				<else />
			</a>
	</span>
</h3>
		<div id='stats'>
			<dl>
				<dt>
				</dt>
				<dd>
				</dd>
				<dt>
				</dt>
				<dd>
				</dd>
				<dt>
				</dt>
				<dd>
				</dd>
				<dt>
				</dt>
				<dd>
				</dd>
				<dt>
				</dt>
				<dd>
				</dd>
			</dl>
				<h2>
					<span class='desc'>
					</span>
				</h2>
				<p>
				</p>
Autor namieszał w kodzie, poprawił to u siebie na forum, ale obecnie jest zamknięte (trwają prace).
Powinno działać to
