pierwszy mail
Cytat
Exception:
IPS\Db\Exception Object
    [query] => DELETE FROM `core_view_updates` WHERE classname=? AND id=?
    [binds] => Array
            [0] => IPS\forums\Topic
            [1] => 11401
    [message:protected] => Prepared statement needs to be re-prepared
    [string:Exception:private] =>
    [code:protected] => 1615
    [file:protected] => /home/klubmalawi/domains/forum.klub-malawi.pl/public_html/system/Db/Db.php
    [line:protected] => 671
    [trace:Exception:private] => Array
            [0] => Array
                    [file] => /home/klubmalawi/domains/forum.klub-malawi.pl/public_html/system/Db/Db.php
                    [line] => 1280
                    [function] => preparedQuery
                    [class] => IPS\_Db
                    [type] => ->
                    [args] => Array
                            [0] => /*IPS\core\tasks\_viewupdates::IPS\core\tasks\{closure}:356*/ DELETE FROM `core_view_updates` WHERE classname=? AND id=?
                            [1] => Array
                                    [1] => 11401
            [1] => Array
                    [file] => /home/klubmalawi/domains/forum.klub-malawi.pl/public_html/applications/core/tasks/viewupdates.php
                    [line] => 60
                    [function] => delete
                    [class] => IPS\_Db
                    [type] => ->
                    [args] => Array
                            [0] => core_view_updates
                            [1] => Array
                                    [0] => classname=? AND id=?
                                    [1] => IPS\forums\Topic
                                    [2] => 11401
            [2] => Array
                    [file] => /home/klubmalawi/domains/forum.klub-malawi.pl/public_html/system/Task/Task.php
                    [line] => 356
                    [function] => IPS\core\tasks\{closure}
                    [class] => IPS\core\tasks\_viewupdates
                    [type] => ->
                    [args] => Array
            [3] => Array
                    [line] => 99
                    [function] => runUntilTimeout
                    [class] => IPS\_Task
                    [type] => ->
                    [args] => Array
                            [0] => Closure Object
                                    [this] => IPS\core\tasks\viewupdates Object
                                            [caches:protected] => Array
                                            [_data:protected] => Array
                                                    [id] => 1841
                                                    [key] => viewupdates
                                                    [frequency] => P0Y0M0DT0H5M0S
                                                    [next_run] => 1567119661
                                                    [running] => 1
                                                    [enabled] => 1
                                                    [plugin] =>
                                                    [app] => core
                                                    [lock_count] => 0
                                                    [last_run] => 1567116063
                                            [_new:protected] =>
                                            [changed] => Array
                                            [skipCloneDuplication] =>
            [4] => Array
                    [line] => 255
                    [function] => execute
                    [type] => ->
                    [args] => Array
            [5] => Array
                    [line] => 224
                    [function] => run
                    [type] => ->
                    [args] => Array
            [6] => Array
                    [file] => /home/klubmalawi/domains/forum.klub-malawi.pl/public_html/applications/core/interface/task/task.php
                    [line] => 62
                    [function] => runAndLog
                    [type] => ->
                    [args] => Array
    [previous:Exception:private] =>
D
Cytat
Exception:
    [query] => SELECT core_reputation_index.member_received as themember, SUM(rep_rating) as rep FROM `core_reputation_index`  LEFT JOIN `core_members` ON core_members.member_id=core_reputation_index.member_received WHERE member_received > 0 AND rep_date BETWEEN ? and ? AND 1=1 GROUP BY `themember` ORDER BY rep DESC, themember ASC LIMIT 4
    [binds] => Array
            [0] => 1566950401
            [1] => 1567036799
            [0] => Array
                    [file] => /home/klubmalawi/domains/forum.klub-malawi.pl/public_html/system/Db/Select.php
                    [line] => 373
                    [class] => IPS\_Db
                    [type] => ->
                    [args] => Array
                            [0] => /*IPS\core\tasks\_leaderboard::execute:255*/ SELECT core_reputation_index.member_received as themember, SUM(rep_rating) as rep FROM `core_reputation_index`  LEFT JOIN `core_members` ON core_members.member_id=core_reputation_index.member_received WHERE member_received > 0 AND rep_date BETWEEN ? and ? AND 1=1 GROUP BY `themember` ORDER BY rep DESC, themember ASC LIMIT 4
                            [1] => Array
                                    [0] => 1566950401
                                    [1] => 1567036799
                            [2] => 1
            [1] => Array
                    [line] => 271
                    [function] => runQuery
                    [class] => IPS\Db\_Select
                    [type] => ->
                    [args] => Array
            [2] => Array
                    [file] => /home/klubmalawi/domains/forum.klub-malawi.pl/public_html/applications/core/tasks/leaderboard.php
                    [line] => 84
                    [function] => setKeyField
                    [type] => ->
                    [args] => Array
                            [0] => themember
            [3] => Array
                    [line] => 255
                    [class] => IPS\core\tasks\_leaderboard
                    [type] => ->
                    [args] => Array
            [4] => Array
                    [line] => 224
                    [function] => run
                    [type] => ->
                    [args] => Array
            [5] => Array
                    [line] => 62
                    [type] => ->
                    [args] => Array
rugi mail
  • 2 miesiące temu...
W dniu 15.06.2019 o 10:12, DawPi napisał:
No nie wiem. Pełno zależności jest. Najprościej napisać, choć w 99% będzie to odpowiedź w stylu "U nas ok, proszę zoptymalizować skrypty". Tylko skoro coś działa cały czas, nic nie było robione, to co najmniej dziwne jest, że nagle przestaje i wina skryptu. Choć są różne sytuacje tak naprawdę.
To? To śpiewka "serwermanów". IPS4 sam w sobie jest na bieżąco optymalizowany i ma wszelkie możliwe i dobre systemy cache. Redisa próbowaliście?
Włączyli nam redis ale ACP to samo co przy poprzednim screenie. Nie da się zaznaczyć.
Do pisali aby pamiętać aby w ustawieniach PHP włączyć redis.
Edit.
Aha w ust. PHP na serwerze. W ACP pojawiła się możliwość włączenia.
Edytowane przez Klub Malawi
